Nebula Reports AP ( NWA50AX ) Offline, Netconf connection is disconnected
Alan_Twigg1951
Alan_Twigg1951 Posts: 5
image  Freshman Member
Netconf connection is disconnected, followed by Netconf connection is connected.
Nebula marks the AP as offline, however clients are still connected and do not lose the connection. This situation lasts for a couple of minutes then all is well again.
I have 2x NwA50AX configured in a Mesh scenario, 1 AP is connected to my router ( BT Smart Hub ) via ethernet ( 1GB ), the other AP is a Mesh Repeater and connects to the master AP via 5Ghz wi-fi, currently this connection shows as uplink signal level -59
rate: 864/648
I see this error on both of my AP's, daily and both AP's have static ip addresses with Google DNS, 8.8.8.8. I have replaced all my ethernet cables between the AP and router.
When I get this offline error? I am able to telnet to d.nebula.zyxel.com on port 4335 from a linux device connected to the same ethernet switch as my main AP.
Both AP's firmware are , V7.10(ABYW.4)
Any help appreciated
Alan
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,095
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 1000 Comments
    image  Zyxel Employee
    Hi @Alan_Twigg1951,
    Sorry for the late reply!
    Below are log excerpts retrieved from the main AP:
    2026/06/28 15:15:20:
    Session of client 'd.nebula.zyxel.com' did not send/receive an RPC for too long, disconnecting.
    client_free_tls: internal error: freeing a client with an opened NC session
    Please allow me to clarify that the AP stopped receiving the periodic keep-alive RPC from Nebula (NCC) in time, so it considered the management session disconnected and established a new connection. During this period, Nebula may report the AP as offline, while local WiFi service continues to operate normally.
    Based on our experience with similar cases, this type of RPC timeout is usually not caused by the AP itself. Instead, it is more commonly related to intermittent packet loss or network instability somewhere along the path to the Nebula cloud, such as on the gateway, upstream network, or ISP side.
    (Suggested)
    1. Check with BT whether there are any known stability issues or session limitations on your Internet connection.
    2. If possible, run a packet capture on the WAN side to check whether packets are being dropped or delayed.
    3. If possible, test the AP using a different ISP connection to determine whether the issue is related to the current WAN path.
    Zyxel Tina
  • Zyxel_Tina
    edited July 7
    Hi @Alan_Twigg1951,
    Welcome to the Zyxel Community!
    From the logs of your device, we found that the AP repeatedly disconnects from and reconnects to NCC due to RPC timeout.
    Based on past experience, this typically happens as follows: NCC communicates with the AP at regular intervals. If there is packet loss on the uplink network, the AP may not receive the RPC polling in time, and will assume the connection session with NCC has timed out — at which point it disconnects and re-establishes the connection via Call Home. In other words, this is mainly related to the overall network environment, meaning the internet path to the Nebula server may be unstable.
    Therefore, we'd suggest checking on the ISP and router side for any anomalies, for example confirming whether session limits are being applied, or capturing packets to check for packet loss.
    Zyxel Tina
  • Alan_Twigg1951
    So I contact my ISP (BT in the UK ) and say "You have an unstable network" please fixit?
    I really dont think they will respond to this, it would be far simpler to relax your " rpc polling window" or at least provide a "switch" within nebula to cater for "slow" networks, job done.
  • Zyxel_Tina
    Hi @Alan_Twigg1951,
    (Suggested)
    Zyxel Tina
