USG FLEX 100->USG FLEX 50H conversion?
jliu
jliu Posts: 6
image  Freshman Member
I have an USG FLEX 100 router and would like to use/convert its configuration to an USG FLEX 50H router. What would be the best steps to perform this conversion of USG FLEX 100->USG FLEX 50H? Thanks.
Jimmy
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,046
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 500 Comments
    image  Zyxel Employee
    Hi @jliu,
    As the converter tool is unable to convert the configuration from the USG FLEX 100 to the USG FLEX 50H. When using the USG FLEX 100 as the source firewall, the Zyxel Security Appliance Configuration Converter only supports converting the configuration to the USG FLEX 100H.
    If you would like to configure based on your USG FLEX 100 configuration, we suggest the following steps:
    1. Download the default configuration file for the USG FLEX 50H.
    2. Manually update the interface-related settings to match your requirements.
    3. For non-interface-related settings, you may copy them directly from the USG FLEX 100 configuration.
    4. Upload the updated configuration file to the USG FLEX 50H.
    Zyxel Tina
  • Zyxel_Tina
    Hi @jliu,
    Zyxel Tina
