Older Firmware for USG FLEX 500
Good evening,
I am requesting assistance regarding a Zyxel USG FLEX 500 firewall that is experiencing a firmware corruption issue on Partition 1.
Partition 1 (Standby): Non functional/corrupted. Original firmware version: v5.20 (ABUJ.0).
Partition 2 (Running/Active): Fully functional. The firewall was successfully booted from this partition via console. Firmware version: v5.30 (ABUJ.0).
My goal is to upgrade the firewall to the latest available version.
Are there intermediate versions available online to perform a step-by-step upgrade of the standby partition since?
I have already checked both the Download Library and the End-of-Life page, but I could only find versions v5.40, v5.41, and v5.42.
Where can I locate the older firmware releases (v5.30, v.5.35, v.5.36) required to safely upgrade my USG FLEX 500? Could you please provide me with those versions?
Hi @CscCsc ,
Older firmware releases are archived and not publicly listed on our standard Download Library to ensure users always install the most secure, up-to-date versions.
In your case, you can upgrade the standby partition directly from 5.30P0 to 5.42P1. After rebooting, the firmware status will look like this: the standby partition is 5.30P0, and the running partition is 5.42P1.
Zyxel_Judy
Hi Judy, thank you for your help.
I managed to solve the issue and would like to share the procedure for anyone experiencing the same problem.
The direct GUI/Cloud upgrade always returned “Firmware not compatible!”. I connected through the serial console (115200, 8N1), entered Debug Mode and kept Partition 2 with V5.30 as the working fallback.
I selected the standby Partition 1 with
atcd 1, configured recovery withatkz -f -l 192.168.1.1, and started it withatgof. I then connected a PC to port 2 and uploaded the firmware through anonymous FTP in binary mode.Using this method, I first restored the corrupted partition to V5.30 and then installed the official V5.36P2 (
536ABUJ2C0.bin) on it. After successfully booting V5.36P2, the Cloud upgrade to V5.42P1 worked correctly, and I was then able to update both partitions to V5.42P1.0
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
