Firmware Upgrade Path for GS1900-24HP
bstvt
bstvt Posts: 2 image  Freshman Member
Dear Support Team,
I am currently using a GS1900-24HP switch with firmware version V2.40 (AAHM.1)_20180705.
I would like to upgrade the firmware, but on your website I can only find version V2.90 available for download. I am unsure whether the upgrade needs to be performed step-by-step through intermediate versions, or if it is possible to upgrade directly from V2.40 to V2.90.
Could you please advise on the correct upgrade procedure? If a step-by-step upgrade is required, I would appreciate it if you could provide the necessary intermediate firmware versions.
Thank you for your support.
Kind regards,
Brian Staub
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,174
    image  Zyxel Employee
    Hi @bstvt
    From the firmware code you mentioned, it seems like your GS1900-24HP is v1 version that its latest firmware version is 2.70 patch 3, not V2.90. Please check my message to find the download link.
    Additionally, you can directly upgrade to latest firmware version without a step-by-step upgrade.
    Zyxel Melen
