Extremely slow communication between LAN1 and LAN2 on the USG60
pieroCastampi
in Security
Traffic between LAN1 and LAN2 is extremely slow. I am not sure if replacing the USG with a more modern device would solve the issue. So, I was considering a Layer 3 switch to handle the traffic between the two LANs. Is this a viable solution? And if so, could you recommend a suitable product?
Yes the USG60 may be at a hardware limit to do the routing a Layer 3 switch setup up correctly with the USG60 can off load the traffic to go by the switch.
something like a XS1935-10 or XGS2220-30
Ok, grazie
- 241 Nebula Ideas
- 6.8K Security
- 757 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 518 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
