Primary WAN not returning after connectivity failure on FLEX 200H
nielsscheldeman
nielsscheldeman Posts: 133
image  Ally Member
edited October 1 in USG FLEX H Series
It now happened for the 2nd time on our appliance. On 2:45:22 this night our provider went down and internet switches to WAN2. 2:46:17 WAN1 got it's connectivity back. However, our internal network and VLAN's still went online through WAN2. Had to force it by disabling WAN2 for a second(we did that on 09:00, so hours after the failure).
WAN1 definitely worked, because our portforwards listen to that port and they worked.
I have connectivity check every 30 seconds to 8.8.8.8 and on Trunk I have "Force Reconnect on Active WAN" turned on.
What could be the issue? Bug? Firmware is 1.39(ABWV.0)
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,283
    image  Zyxel Employee
    Update:
    This issue is fixed in V1.40 firmware.
    Zyxel Melen
  • Zyxel_Melen
    Hi @nielsscheldeman
    This issue has been addressed and will be fixed in future firmware release. Please also check the private message I sent for the weekly firmware.
    Zyxel Melen
  • nielsscheldeman
    image  Ally Member
    Ok, when will it be official released? I might wait for it so I can update it through Nebula over night.
  • Zyxel_Melen
    The ETA is 10/19.
    Zyxel Melen
  • Dylan96
    Dylan96 Posts: 47
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
    image  Freshman Member
    Hi @Zyxel_Melen,
    We're experiencing the same issue. I opened a ticket and was provided with the following ITS, but the problem persists:
    1.39(ABWV.0)ITS-26WK36-m12745
    Do you have a newer ITS?
  • Zyxel_Melen
    Hi @Dylan96
    Sent.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    Zyxel Melen
