Are GRE tunnel going to happen for FLEX H?
So I know L2TP over IPSec is not going to happen but what about GRE tunnel?
Hi @PeterUK
Thanks for your follow-up. I’ve checked with our product team, and unfortunately GRE tunnel is currently not supported on the H series, and there is no plan to add it at this time, as this feature is less commonly used in SMB networks.
To help us better understand your needs, could you share more about your scenario (e.g., what devices or sites you’re trying to connect, and what you’re planning to achieve with GRE)? Your feedback will be shared with our product team for future consideration.
Zyxel Melen0 -
Hi Melen
So what I have achieved is a simple tunnel for devices to use locally its not a problem if GRE will not added I just needed to to know so I can do VTI to replace GRE if FLEX H will never have it added.
The other thing is performance GRE vs VTI do you know if one performs better by max throughput?
Hi @PeterUK
Short answer: with the same CPU and the same encryption/authentication algorithms, VTI is slightly faster than GRE over IPsec.
Why
With GRE over IPsec, each packet gets an extra GRE header and a new outer IP header (about 24 bytes) before IPsec encrypts it. VTI skips this step and sends the traffic straight into the IPsec tunnel.
Both tunnels still use the same 1500-byte MTU. That means GRE’s extra header takes space that would otherwise carry data, so each packet carries less real data and the TCP MSS has to be smaller.
A simple way to picture it
Think of each tunnel as a truck of the same size:
- VTI: the whole truck is used for parcels.
- GRE over IPsec: part of the truck is taken up by GRE’s extra packaging, so it carries fewer parcels per trip.
Over many trips, VTI moves a bit more data in the same time. GRE over IPsec also adds one more wrap/unwrap step for the device to process.
In practice
The difference is small. The extra header is only a few percent of a full-size packet. If you need GRE features, such as multicast or routing protocols like OSPF over the tunnel, GRE over IPsec is still a good choice. If you only need plain encrypted site-to-site traffic, VTI is simpler and a little more efficient.
I’ve attached a diagram for reference in below. Note: It is made with AI to show the idea, not taken from a real packet capture.
(I say “GRE over IPsec” throughout because “GRE” alone usually means plain GRE without encryption.)
Zyxel Melen0 -
but the GRE tunnel has no encryption? it has no option to do that
That would fast than VTI, since the packet header of GRE packet is 24 byte, which is shorter than others.
Packet type
Extra headers
Encrypted
Plain GRE
24 B
No
VTI
about 50–75 B
Yes
GRE over IPsec (transport mode)
VTI’s overhead + 4 B (GRE header only)
Yes
GRE over IPsec (tunnel mode)
VTI’s overhead + 24 B (GRE IP + GRE header)
Yes
Therefore, the comparison is GRE > VTI VPN > GRE over IPSec.
Zyxel Melen0 -
Ok so back to are Zyxel going to add GRE tunnel for for FLEX H? its not a problem if they think its obsolete I moved one setup to VTI.
Hi @PeterUK
Confirmed with our product team GRE tunnel is not in our roadmap. It is recommended to use VTI VPN.
Zyxel Melen1
- 244 Nebula Ideas
- 6.9K Security
- 806 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
