USG FLEX 200H blocks traffic from LAN1 to LAN2
pieroCastampi
pieroCastampi Posts: 45
image  Freshman Member
Good evening. The USG FLEX 200H device is blocking traffic from LAN2 to LAN1, even though the policy is correctly configured. Conversely, traffic from LAN1 to LAN2 works fine. I have placed the rule in position 1 to avoid any potential conflicts, but it still does not work. The USG FLEX is running the latest firmware, v1.40 ABWV.0. I have attached the rule. Thank you.
«1
    PeterUK Posts: 4,796
    image  Guru Member
    Seems fine here.
    Can you Wireshark one end to ping from another?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,174
    image  Zyxel Employee
    Hi @pieroCastampi
    Seems like your LAN2 is a separate zone from LAN1. Please ensure you have set "LAN2 to ZyWall any to any" allow rule first. If not, the firewall will not help to router the traffic.
    Additionally, you may use tracert/traceroute <Windows/Linux> to check where the connection loss.
    Zyxel Melen
  • pieroCastampi
    Unfortunately, I don’t know how to use Wireshark. In any case, I set up a rule—number 1: LAN2 to ZyWALL, any, any—but nothing changed. I’ve attached the log entry that shows the traffic being blocked. Grazie
  • pieroCastampi
  • pieroCastampi
    Sorry for the mess; it wouldn't let me upload the image of the rule. 192.168.10.2 is LAN2, while 192.168.1.225 is LAN1.
  • Zyxel_Melen
    That means the traffic doesn't match any rule of your security policy. Please share your interface configuration with us. I will also send you a private message to get your start-up config file.
    Zyxel Melen
    image  Guru Member
    can you try a simple rule from LAN2 to LAN with source and destination to any
  • pieroCastampi
    PeterUK Thanks, but I’ve already tried that; it doesn’t work. I have sent the configuration files to Zyxel_melen
    image  Guru Member
    edited October 20
    Very odd… I know "override-direct-route" can cause this if you have a routeing from LAN to WAN but that should be off…
    Ok I have one more idea make this top routing rule
    incoming LAN2
    source LAN2 subnet
    destination LAN subnet
    next hop LAN
    SNAT none
    and another rule
    incoming LAN
    source LAN subnet
    destination LAN2 subnet
    next hop LAN2
    SNAT none
    Or maybe wrong set zone?
  • pieroCastampi
    Buonasera, in effetti la zona Lan2 l'ho creata io, di default c'era solo Lan. Avrò commesso un errore nel crearla? Cosa possiamo verificare? Grazie
