LLDP chassis name is being ignored in nebula-managed switches
I am testing using the native windows LLDP agent to provide basic data to switches and routers but I am seeing a logic issue on my Zyxel switches.
Devices with both system and chassis name populated are shown while devices with just chassis name are being ignored. Windows sadly only sends chassis name and interface MAC for each active interface.
If there is LLDP data but no system name, it should make sense for the chassis name to be used as a neighbor name.
Is this a bug? My netgear switches populate their neighbors table correctly with the same kind of data.
Hi @matteosaitta ,
This is expected behavior, not a bug: the Neighbor Table currently shows the System Name only when present, with no fallback to Chassis ID. To check the chassis name in the switch, please use the CLI as
show lldp info remoteA fallback to Chassis ID when System Name is missing would be a useful improvement, so we submitted this as an Idea Post here:
Support Chassis ID Fallback in LLDP Neighbor Table When System Name Is Absent — Zyxel Community
Zyxel_Judy
I guess you are claiming that the switch web cannot see device with only sending chassis name in LLDP pakcet since there is no such a column called "Chassis name", but you can check the chassis name in the switch CLI by typing
show lldp info remote0 -
Hi @matteosaitta ,
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
