How to create Mesh with 2 pcs of EE5301-EE? Missing commands..
Hi, I have a couple of EE5301's and I try to create Mesh with these, I got help wit AI but unfortunately those commands are not visible in my navigate pages. I'm not original owner of those units but I ordered those from netshop. I think that local ISP or so has modified commands out of DIY's. Also there are not any logs available to me.
KInd regards, Matti
"To bypass this and build a functional mesh system with your two identical routers, use the definitive bypass sequence:
Step 1: Change the Role of the 2nd Unit to "Agent"
Before connecting the two routers together, you must strip the second EE5301 of its routing authority. [1, 2]
- Unplug the second EE5301 from everything except power.
- Connect a computer or phone directly to this second unit's default Wi-Fi (printed on its label).
- Open a browser and navigate to its local admin page (192.168.1.1). Log in using the admin credentials on its back label.
- Go to Network Setting > Wireless > MESH.
- Look for the Device Role setting (it defaults to Controller). Switch this setting to Agent (or Extender / AP Mode depending on your exact firmware version).
- Disable DHCP on this second unit to ensure it doesn't conflict with your main router.
- Save and apply the settings. The unit may reboot. [1, 2, 3, 4, 5, 6]
Step 2: Perform a Hardwired Mesh Sync
Wireless pairing via WPS often fails when force-configuring two full-fledged routers. You must establish the mesh link with a cable first. [1, 2, 3]
- Keep the main (WAN-connected) EE5301 fully running.
- Take an Ethernet cable and plug one end into a LAN port on the Main Router.
- Plug the other end into the WAN port (or LAN 1) of your newly reconfigured 2nd Router.
- Leave them connected like this for 3 to 5 minutes. The main router will detect the Agent unit over the wire, override its wireless settings, copy its own Wi-Fi SSID/password over to it, and bind them into a single MPro Mesh network. [1, 2, 3, 4, 5]
Step 3: Wireless Deployment (Optional)
Once the Link/Mesh LED on the second unit stabilizes to a solid green state while hardwired, the mesh config has succeeded. [1]
- If you want a wired mesh backhaul (highly recommended for performance), leave the cable exactly where it is and place the unit.
- If you want a wireless mesh connection, unplug the Ethernet cable. Move the second unit to its permanent location (ideally halfway between the main router and your Wi-Fi dead zone) and power it on. It will now automatically connect wirelessly to the master unit using the configuration it just learned. [1, 2]"
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 389 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 325 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 122 Security Highlight
