WLAN time-controlled and protocol more than 500 entries
hier in Englisch:
is it possible to switch the WLAN on and off with display control? Maybe with a script?
I would also like to know if I can make the protocol save more than 500 entries?
Thanks for your help!
Hi @bdb
On models such as USG20W/USG40W/USG60W.
You can enable and disable the function WLAN control on easy mode dashboard.
The user defined protocol can reach up to 255 protocol.
You can add your Service Rule by following steps.
Go to Configuration > Object > Service> Service > Add
That wasn't exactly my question. I guess I wasn't clear either.
I would like to have the WLAN switched on and off automatically and time-controlled.
Regarding protocol I didn't mean the TCP but the LOG entries. No more than 500 are stored here.
Hi @bdb
May I know what model and firmware are you current using?
Hi @bdb
1 . The schedule can be setup by following steps.
Go to Configuration > Object > AP Profile > SSID > SSID List > select the rule > Edit the rule
Arrange the schedule of SSID
2 . The current design of the log display on USG20W-VPN is up to 512 entries,
If need to save more logs, then route the logs to an external host .
Go to Configuration > Log & Report > Log Settings > select the Remote Server > Edit
Select the log need to be collect
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
