nwa1123-ac hd uplink currently operates at a lower speed 100mb
jerryH
jerryH Posts: 2
image  Freshman Member
edited May 2024 in Wireless
  • 唐小鴨
    唐小鴨 Posts: 7
    First Answer First Comment Friend Collector
    Did you change the cable or port on switch? I got uplink 100M issue but it's resolved by changing the cable, so maybe you can try and do a test for it.
  • UnDutchable30
    UnDutchable30 Posts: 5
    First Comment Seventh Anniversary Nebula Gratitude
    I have noticed the same problem, only 1 AP has this, the others are just fine. They are all connected to the same switch and ports has been changed already.
  • jerryH
    jerryH Posts: 2
    I put the AP in question on a known good cable from another AP and its speed was set to 1000M. I put the questionable AP back on the old cable it was on before and all is good. Been up and running for 3 weeks now with no problems. Still trying to figure that one out?
