Expert mode and easy mode
Marko75
Marko75 Posts: 6
image  Freshman Member
edited April 2021 in Security
After updating to the latest firmware version 4.35 (AAKZ.3) I receive this message if I want to change the settings of the VPN in use on the device. How can I solve it? Thank you.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406
    image  Zyxel Employee
    Hi @Marko75
    You can setup the VPN Wizard again to modify the VPN setting on EZmode.
  • DannyC
    DannyC Posts: 10
    Hi, I was playing around VPN setting in EZmode, how do I delete it?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,499
    Hi @DannyC,
    The settings configured in Easy Mode cannot be modified in Expert Mode. It is to avoid settings conflict between different modes.
    To delete VPN settings which are created in Easy Mode, switch to Expert Mode and delete the EZMODE_VPN rule.
    If you'd like to configure advanced settings in VPN Gateway and VPN Connection, just start directly with Expert Mode to configure in CONFIGURATION > VPN.
  • danieles
    danieles Posts: 3
    I'm not able to delete EZMODE_VPN_L2TP neither in Easy Mode nor Expert Mode. How to preceed?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    @danieles
    The case seems the similar with another thread you created, therefore we could discuss it on below link:
    https://businessforum.zyxel.com/discussion/5059/impossible-to-remove-ezmode-vpn-l2tp#latest
