URGENT HELP zywall usg DEAD - how to retrieve rules
Hello my name is Mauro Blandizio of Phema srl,
I am writing to you because zyxel firewall has died 2 days ago. we tried to change the power supply but it doesn't boot.
we bought another firewall but we have to write all the rules again and we haven't saved all the rules in a backup or something. there's a way to retrieve all the rules and data like with a special emergency mode or something like that?
Thank you very much for everything.
Does the device reboot continually? or there is not LED blinking on the device?0
hi jeremy
power led is on
sys led keeps blinking0 -
@Mauro_Phema_srl
You may try this way first to see it can be working or not. From console, enter debug mode and type “atkz –b”and Use “atgo” booting device, and after device reboot,
you can get the old configuration. The name of configuration will be"startup-config-back.conf"
could you also explain me how to enter in console mode and debug mode?Zyxel_Charlie said:@Mauro_Phema_srlYou may try this way first to see it can be working or not. From console, enter debug mode and type “atkz –b”and Use “atgo” booting device, and after device reboot,
thank you very much charlie!
@Mauro_Phema_srl
Can I know what is your model?
You need to have console cable(RS232), and install the tera term application.
On tera term, select Serial with proper Port, then go to Setup>Serial Port>115200 on Baud rate.
Next, reboot the device and press any key in 3 secs, and you will access debug mode.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
