ATP200 Wan/Lan Bridge Mode with VLANs
MartyWalter
We are installing an ATP200 between a customers VPN100 and their network (as suggested by ZyXEL sales). The VPN100 (in SDWAN mode) has the native VLAN as well as two VLANs for voice/guest traffic.
We are struggling with passing the Voice/Guest vlans across the bridged ATP200.
If anyone has a suggestions for the proper settings in the ATP200, it would be greatly appreciated.
@MartyWalter
Regarding to your description,
the configuration of Vlan on VPN100 need to configure untag, and bridge Wan and Lan interface on ATP200 then check it again.
This is exactly how we have the ATP200 programmed. It does not pass vlan7 or vlan10 from the VPN100 to the network.0
Maybe you need to make VLAN 7 and 10 on the ATP200 base port LAN1 then add them in the Bridge?
I tried that, the issue was that then the vlan7 dhcp started serving up addresses on the native vlan.0
@MartyWalter
Regarding to this case,
The ATP200 doesn't support VLAN trunk on bridge mode. It supports mainly un-tagged traffic.
- 235 Nebula Ideas
- 6.7K Security
- 732 USG FLEX H Series
- 374 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 117 Security Highlight
