Big speed hit with bandwidth management enabled on VPN2S
With VPN2S V1.20(ABLN.2) 00201030C1
Setup test on the VPN2S
WAN set to 192.168.255.55/255.255.255.0
PC1 connected to WAN on VPN2S IP 192.168.255.53/255.255.255.0
LAN2 192.168.2.1/255.255.255.0
PC2 connected to LAN2 on VPN2S with IP 192.168.2.2/255.255.255.0 gateway 192.168.2.1
Doing a transfer test with MS file share without bandwidth management enabled is 950Mb
Doing a transfer test with MS file share with bandwidth management enabled just set to 1048576 gets 50Mb
Side question for VPN2S and bwm: is possible to set a lower than 1024kbs for upstream?
Well thanks, i already read that. And IMVHO there are connections which the actual upload rate is... lower. Therefore, less than 1000 kbps should be a value that could be inserted...
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
