Is there any way to change MTU(Maximum Transmission Unit) on GS1900-8?
nospherato
nospherato image  Freshman Member
edited August 2022 in Switch
Hi all,
I recently bought a ZyXel GS1900-8 Switch and now I have got a little problem:
I need to change my MTU to 1412 (using hybrid internet connection and can not change it router sided).
In the webinterface (newest firmware) I only found the option to set 802.3 maximum fame size, but not setting a custom frame size.
Is there any way to configure a custom frame size per port (or global for all ports)? Perhaps via CLI/telnet?
Best wishes
nospherato
#Biz_Switch_February
