Jason
Can I use an ES-105A v3 as a Power over Ethernet Switch
keith21250
I want to use an ES-105A v3 as a Power over Ethernet switch between my router and an external camera
Hi @keith21250 ,
Welcome to Zyxel Community!
ES-105Av3 is not a PoE Switch, so it doesn't have PoE feature.
Here are some other PoE model for you to reference:- PoE12-HP - It is a PoE Injector for the user that only needs one PoE port.
https://www.zyxel.com/products_services/802-3af-at-PoE-Injector-PoE12-HP/ - GS1005HP - It is an Unmanaged Switch with 4 PoE ports.
https://www.zyxel.com/products_services/5-Port-GbE-Unmanaged-PoE-Switch-GS1005HP/ - GS1200-5HP - It is a Web Managed Switch with 4 PoE ports.
https://www.zyxel.com/products_services/5-Port-8-Port-Web-Managed-PoE-Gigabit-Switch-GS1200-5HP-v2-GS1200-8HP-v2/ - GS1350-6HP - It is a Smart Managed Switch for Surveillance with 5 PoE ports.
https://www.zyxel.com/products_services/Smart-Managed-Switch-For-Surveillance-GS1350-Series/
0 - PoE12-HP - It is a PoE Injector for the user that only needs one PoE port.
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 681 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
