USG210 temperature
Good morning.
How many temperature sensors is in the USG210?
What are the maximum allowable temperatures of these sensors in the USG210?
My USG210 immediately after running shows:
After a few minutes, after warming up and after turning on the fan, it shows:
After a next few minutes, after cooling and turning off the fan, it shows:
Are the sensor [2] readings correct (128 degree)?
Or maybe the USG210 has only sensors [0] and [1]?
Sorry for my English.
Regards
Wojtek
Regards
Wojtek
Hi @Wojtek,
Thanks for your feedback, it is an issue on device sensor, we will put it in bug fixing queue.
Thank you for your answer.
Regards
Wojtek
After firmware upgrade to version 4.32, the problem still exists
Hi @Wojtek
The sensor information will not effects device stability issue.
So it is put in lower priority to fix it.
Hi
This KB article (https://support.zyxel.eu/hc/en-us/articles/360005174640-Is-it-possible-to-find-out-the-temperature-of-the-processor-and-motherboard-in-the-ZyWALL-110-310-1100) describes that the sensor [0] = CPU temperature and
Sensor [1] = board temperature is.
What is measured on the sensor [2]?
Thank you for the quick reply.
best regards
dashmir
Hi @Manuel
You may ignore the sensor [2] temporarily. The information is incorrect.
We will correct it in Q4/2019.
Corrected.
Thank you.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
