gs1920-24hpv2 non-interactive ssh `invalid command`
R4scal
R4scal Posts: 2
image  Freshman Member
edited August 2022 in Switch
Hi
  1. when i logged in ssh session and execute `show system-information` - all works fine
  2. when i execute `ssh admin@192.168.0.254 show system-information` - Received disconnect from 192.168.0.254 port 22:2: invalid command system-information.
Is there any way to make this work?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 306
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    image  Zyxel Employee
    Hi @R4scal
    Zyxel switch currently doesn't support such command to directly ask the info.
    It seems to us that your goal is to poll data from devices, our suggestion would be to use SNMP or create a script.
    Zyxel_Lucious
  • R4scal
    R4scal Posts: 2
    @Zyxel_Lucious Thanks for answer
    Any plans to add support of directly ask the info? It's really needed, because snmp doesn't have enough metrics about environment and poe ports
  • Zyxel_Lucious
    edited November 2019
    Hi @R4scal
    There is no plan for this feature due to internal concern which involves security breach.
    For now, a script SSH is rather recommended for your demand.
    Zyxel_Lucious
  • yellowlanport
    yellowlanport Posts: 1 image  Freshman Member
    Time for forum thread necromancy..
    I came across this problem, tried many methods to get around it. This one just about works but is unreliable. It looks like the switch might terminate the connection after the command has run but before all the command output has been sent over the SSH session.
    echo -e "show interfaces status\nshow version\n" | sshpass -p 'routerpasswordhere' ssh -v admin@router.ip.address.here
    Eventually I've found a reliable method is using the linux utility "expect". Here is a very simple example file. Make the file then chmod to +x and then run it. (obviously make sure you've installed expect (e.g. apt install expect).)
    #!/usr/bin/expect -f
    set username [lindex $argv 0];
    set ip [lindex $argv 1];
    spawn ssh $username@$ip
    expect "password: "
    send "INSERTPASSHERE\r"
    expect "# "
    send "show version\r"
    expect "# "
    send "show interfaces status\r"
    expect "# "
    send "show mac address-table all\r"
    expect "# "
    send "exit\r"
    I then call the script using ./switch_info_fetcher techsupport 10.11.12.4
    I hope the above advice helps someone else searching for the answers.
