Zyxel WAC - Filesystem /compress full
JaapHoetmer
JaapHoetmer Posts: 3 image  Freshman Member
Friend Collector Fourth Anniversary
edited May 2024 in Wireless
Hello
Our monitoring system reports that the filesytem /compress is full, on a couple of access points. The access points are managed through a NXC2500. What can we do about this, is the filesystem accessible, what is stored on it and can it be cleaned? If so, how can we achieve this?
Thanks, best regards,
Jaap
  • Zyxel_KathyLin
    Zyxel_KathyLin Posts: 58 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @JaapHoetmer
    Please receive the private message, we will handle it.
  • Zyxel_Richard
    Zyxel_Richard Posts: 255 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    The filesystem/compress is only referred by AP/NXC when initial booting up. Therefore we just allocate adequate size for this folder, it's normal to see it's full or near full. And don't worry, there is no service impact if you see this information on your SNMP server :)
    Best Regards,
    Richard
