VES1724-56 bridge mode
M34NM0f0_
M34NM0f0_ Posts: 1 image  Freshman Member
edited August 2022 in Switch
Hi I am trying to put this switch into bridge mode to allow the DHCP server to handle addressing as the is a video on demand system on the network. I have VMG1312 modems which were set to DHCP but that was messing with the VOD system.
I have now set the modem to bridge mode and the switch to "Global" in IP management/DHCP
The modem shows it's connected but nothing gets an IP address.
What am I missing?
TIA
  • Nikki
    Nikki Posts: 40
    First Comment First Answer Fifth Anniversary
    Hi TIA,
    From your description, seems you changed VMG1312 to bridge mode, but what you mean switch to "Global" in IP management/ DHCP?
    In my experience, only need to configure vlan settings to match on both VES1724-56 and VMG1312. Then PC from CPE lan side should be ok to get the IP address from the dhcp server which connected to VES1724-56 uplink.
    Hope the information is useful.
    or maybe you could contact with your ISP or local distributor.
    Cheers,
