PCI Compliant
I am getting an failed PCI Compliant due to my certificate # 0 port 443 protocol TCP is valid for more than 39 Months. They are saying it cant be more than 27 Months. It says the remedy Please install a server certificate with recommended maximum validity. How do I go about this. Here is the explanation: under Vulnerabilities without an Exception Case
SSL Certificate - Invalid Maximum Validity Date Detected
Description
Starting 1 March 2018, Certification Authorities (CAs) are not permitted to issue SSL certificates (issued from a public root) with a validity period greater than 27 months.
SSL/TLS certificate maximum validity is 825 days (27 months) for Domain Validated (DV) and Organization Validated (OV) Certificates.
SSL certificates have limited validity periods so that the certificate's holder identity information is re-authenticated more frequently.
It is detected that maximum validity of certificate on the system is more than what is recommended.
Thanks for any Help.
OK, thanks. I can't find anything about it.
This is my first experience with a firewall. Where would I get the 3rd party authorization certificate. Thanks
Namecheap 1Yr certificates are super cheap and work great on Zyxel routers. < $10/year.
But you can also just take HTTPS out of the WAN to Zywall service group if you don't use remote admin or SSL VPN.0 -
Thanks Ill check that out.0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
