NWA1123-ACv2 run multiple SSH commands
Erdem
Erdem Posts: 5 image  Freshman Member
edited May 2024 in Wireless
I want to run multiple ssh commands with one line on the AP. I tried to separate the commands with a semicolon (;) and && but I keep getting error. You can see the examples down below.
$ configure terminal; wlan-security-profile TestSecurityProfile; mode wpa2; wpa-encrypt aes; wpa-psk 12345678; idle 3600; reauth 1800; group-key 1800;
$ configure terminal&& wlan-security-profile TestSecurityProfile&& mode wpa2&& wpa-encrypt aes&& wpa-psk 12345678&& idle 3600&& reauth 1800&& group-key 1800;
Which way I should follow to do accomplish this task?
Thank you in advance.
Best regards,
Erdem
