NWA1123-ACv2 Command removed error
Erdem
Erdem Posts: 5
image  Freshman Member
edited May 2024 in Wireless
I am trying to create 5Ghz wlan radio profile from ssh connection but I keep getting "Command removed due to the platform upgrade." error.
I am running following command
Router> configure terminal
Router(config)# wlan-radio-profile testprofile
Router(config-wlan-radio testprofile)# band 5G
% Command removed due to the platform upgrade. You can look up the new commands in the release note or use TAB or ? to get command help.
How to create 5Ghz wlan radio profile?
Best regards,
Erdem
