How to configure Log & Report
Hello guys,
I have an issue with configuring Log & Report, I mean when I go to Configuration->Log & Report->Log Settings and I introduce all the details for "E-mail Server 1" and then I go to the "Email Daily Report" to Send a Report Now and then to Monitor->Log to check if the mail was sent, I received this error: "msmtp: TLS certificate verification failed: unable to get local issuer certificate". I tried to go to Monitor->Log and click on Email Log Now and I received this error: "Sending event/alert log to mail server has failed."
Can Someone please tell me what to do, because to me is weird 100% ?
I also attached few screenshots with how I have configure this Log Settings.
Active Log and Alert
Active Log and Alert (AP)
Log Consolidation
I attached also how I configure Email Daily Report
If you need more info, please let me know.
I forgot to mention, that I turned on this option with "Less secure app access" from GMail, but nothing:
No one can help me with my issue ? Thank you
Hi @Zyxel_Jerry
I did you said there and also I followed the steps from that link, because by that link I did this post and also, those screenshots.
Do you have any other idea what I have to modify ?
Thank you
Regards,
Alex
Hi @zappu
Here is the example setting of smtp
Go to CONFIGURATION > System > Notification > Mail Server to setup setting for Mail Server.
Go to CONFIGURATION > Log & Report > Email Daily Report to Enable Email Daily Report
Go to CONFIGURATION > Log & Report > Log Setting > double click on the System Log to edit it.
After setup all the setting, Go to CONFIGURATION > Log & Report > Email Daily Report click send report now to check.
And you’ll receive the report from the device.
If the issue is still occured, can you send your configuration to us for check further?.
Now I received this message: "Failed to connect to mail server smtp.gmail.com.", after I put that port.
Please let me know what I put wrong ?
Thank you
Alex
Alex... could you post the fix? Having the same issue. Thanks!
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
