Vpn Question On Usg 100
Daniel1981
I Have Usg 100 With Configured 13 VPN IPSEC
NAME - VPN GATEWAY
VPN1 - VPN1
VPN2 - VPN3
VPN3 - VPN3
NAME - VPN GATEWAY
VPN1 - VPN1
VPN2 - VPN3
VPN3 - VPN3
I need to access VPN13 from all VPNs Because from the VPN 1 client I can't access the resources of VPN13.
In VPN1 clients I can't see a server on VPN13.
I can access them are from the resources in the USG 100 network.
Do I have to set routes?How can I do?
You want one VPN tunnel remote access two subnet?
USG100 doesn't support multiple traffic selectors.
Ia have this si
tuation
I also tried to set up an SSL VPN, I reach the ZYXEL router but I do not reach office 7, even if I enter the vpn 7 addresses in the enabled addresses
I also tried to create an SSL VPN to USG 100 from client 1-2-3-4-5-6 I see the usg 100 and its resources but I do not reach headquarters 7 which is connected to the usg 100 in IPSEC. Where am I wrong?
The best is you had a well network IP address planning.
So that the auto routing can work without set up extra policy route.
https://businessforum.zyxel.com/discussion/2259/connecitivity-between-multiple-ip-sec-vpn-connections
Otherwise, you need to configure complex policy routes in each site.
On site 7: add policy route to Site 1-2-3-4-5-6, go into tunnel to USG100
On site 1,2,3,4,5,6: add policy route to site 7, go into tunnel to USG100
On USG100:
Add policy route for site 7 to site 1, go into tunnel to site 1
Add policy route for site 7 to site 2, go into tunnel to site 2
Add policy route for site 7 to site 3, go into tunnel to site 3
Add policy route for site 7 to site 4, go into tunnel to site 4
Add policy route for site 7 to site 5, go into tunnel to site 5
Add policy route for site 7 to site 6, go into tunnel to site 6
Add policy route for site 1-2-3-4-5-6 to site 7, go into tunnel to site 7
Then you can imagine, what if you have 10 more sites even 100 sites
Again, well network planning before you get crazy...1
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
