What description will be displayed, if website be blocked
This discussion was created from comments split from: ATP200 Content Filter.
Sorry my ATP is not installed yet but I have a question.
I want to give Free Wifi for my Guests and block "bad" Sites.For example "Nudity". Do you know what when a News Website have Nude Contend on there Page what happen?Is there a way to show the User why the Page is blocked like: "This Page is blocked for Nudity."Thanks
@Username_is_reserved
If you configure safe search on content Filter, ex: Nudity or Pornography/Sexually Explicit.
After you access the related websites, some of web pages will display as below
some of pages will be blocked directly(No description).
However, all you can check ATP's log message to know which category was hit.
wow can i config this Page to my own Style? I run a Proxy to will will block some thins and both should look like identical. (Well I am happy to see what kind of Sites Zyxel Employee know.)I saw I can make different Filter for different User Groups. Thats good for that.Thanks
I found it! ATP ->
Web Authentication -> Internal Web Portal Customize FileCan I change there the HTML Files to show a different Style?
The page is standard style, and it cannot be customized.
As you mentioned, the customized file from web authentication which is for captive portal function is not related with CF's block page.
However, I would like to add your request to Idea.
Once the ideas get lots of Likes, we will give it to our product developers to have them evaluated and tell you the feedback.
Thanks that would be nice.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
Admin
