Dual Wan based on Content
Is it possible to utilise dual wan capability of USG20-vpn in a such a way that only Netflix,Youtube traffic is handled through 3G USB modem and all other traffic through Other WAN connection?
can somebody guide me how to achieve this?
If you have FQDN support you should be able to do what you want in routing and youtube media stream is by *.googlevideo.com which is a WILDCARD FQDN and the USG picks up DNS to given IP's likely the ISP CDN.
Make a routing rule with incoming Interface member LAN1 then destination the WILDCARD FQDN *.googlevideo.com next hop type Interface to 3G USB.
Now what should happen is the youtube video's will stream over your 3G USB and you must not use DNS over HTTPS.
5
@ Gayanll
Regarding to this case,the USG20 doesn’t support certain purpose since it does not support FQDN(youtube,Netflix).
You can consider the USG20-VPN which can fulfill this kind of deployment.
Sorry i have a USG20-VPN. How to chieve this?0
Can somebody answer pls?0
@ Gayanll
The device only can control the traffic when you connect to youtube website by FQDN, however, the device cannot manage the media stream since it doesnot know the details of media server which behind Youtube website. Therefore, the USG cannot fulfill this scenario.
5 -
Thanks. Thats way looks practical.0
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
