What is script Guest_wifi_timeup.zysh? - Created by EZMode wifi setup
Hi, I ran across this script in my USG60W. Appears to have been created by ezmode. What does it do?
Thanks!
Rickkee
configure terminal
ap-group-profile EZMODE_AP_GROUP
no slot1 ssid-profile 2
no slot2 ssid-profile 2
exit
no schedule-run 2
write
Thanks!
Rickkee
Hi @RickkeeC
The script is for disable local WiFi radio.
If you setup local WiFi to works for a period time, then system will auto run the script.
Then WiFi radio will shutdown automatically when times up.
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 322 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
