Open Port
Hi @serverpal
You can reference to port forwarding FAQ.
The configuration all the same, but your port is 10180.
After configured NAT rule, please also remember allow traffic in policy control rule.
Hi, thank you, this is scenario:
(I have changed port of host from 10180 to 80)
this configuration does not work.
I'd like to connect by pibblic ip and external port 10180:
http://xxx.xxx.xxx.xxx:10180
any help?
thank you.
Odd that should work...I take it lan1 is 192.168.6.1/255.255.255.0?
Does wan1 get a WAN IP or is thier another router doing NAT?
Yes lan is 192.168.6.1/ 255.255.255.0
cable is:
intrrnet to router isp
router isp to wan zywal
Inside router isp there are not nat ports0 -
Is your ISP router in modem mode or bridge mode?
what IP does the wan1 get?0 -
Isp has 102.168.100.1 and wan1 100.2
I dont know the router mode.0 -
Does the dvr secutiry camera setup with IP have a gateway set to 192.168.6.1?
Hi @serverpalAfter you changed your camera service port to 80.You can make sure if it is worked from your LAN side client by 192.168.6.19:80And also make sure you have setup correct policy control rule:0
- Camera ip gateway is 6.254 (to zywal)- yes inside lan 6.19:80 works0
Hi @serverpal
It may need check the issue by HTTPS remote access session. I will send you private message for further check.0
- 431 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 357 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
