Open Port
serverpal
serverpal Posts: 29  Freshman Member
edited April 2021 in Security
hi,
I have my dvr secutiry camera on IP 192.168.6.19 and port 10180 I'd like to connetc from outside (smatphone) .
Inside Lan in browser 192.168.6.19:10180 works, how can I to open outside ? (NAT, Policy...)
thank you.
Damiano
«1
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,388  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @serverpal
    You can reference to port forwarding FAQ.
    The configuration all the same, but your port is 10180.
    After configured NAT rule, please also remember allow traffic in policy control rule.
  • serverpal
    Hi, thank you, this is scenario:
    (I have changed port of host from 10180 to 80)
    this configuration does not work.
    I'd like to connect by pibblic ip and external port 10180:
    http://xxx.xxx.xxx.xxx:10180
    any help?
    thank you.
    PeterUK Posts: 3,757  Guru Member
    Odd that should work...I take it lan1 is 192.168.6.1/255.255.255.0?
    Does wan1 get a WAN IP or is thier another router doing NAT?
  • serverpal
    Yes lan is 192.168.6.1/ 255.255.255.0
    cable is:
    intrrnet to router isp
    router isp to wan zywal
    Inside router isp there are not nat ports
    Is your ISP router in modem mode or bridge mode?
    what IP does the wan1 get?
  • serverpal
    Isp has 102.168.100.1 and wan1 100.2
    I dont know the router mode.
    Does the dvr secutiry camera setup with IP have a gateway set to 192.168.6.1?
  • Zyxel_Stanley
    After you changed your camera service port to 80.
    You can make sure if it is worked from your LAN side client by 192.168.6.19:80
    And also make sure you have setup correct policy control rule:
  • serverpal
    - Camera ip gateway is 6.254 (to zywal)
    - yes inside lan 6.19:80 works
  • Zyxel_Stanley
    Hi @serverpal
    It may need check the issue by HTTPS remote access session. I will send you private message for further check.
