Zywall 310 - IDP signature update failed
EDIT - My apologies, I somehow managed to post this in the wrong forum. I've asked in the Security Services forum now so admins please delete this if required.
I recently purchased a subscription to IDP. I've set everything up but I am unable to update the signature which are currently showing as signature number 2199 - almost 7 years old!
When I attempt to use the 'Update Now' button I get a message to say "IDP signature download has failed. (failed) at...". After the service was activated I left it overnight in the hope that it took a little time to become available to new subscribers, but the problem still persists.
How do I go about getting this working - as it stands, with signatures that old, the service is of limited use.
Thanks.
Hi @SMarkG,Welcome to Zyxel Community.Is this ZyWall310 behind a firewall/NAT/router? You need to allow https outbound traffic if ZyWall310 behind a router.Moreover, DNS server need to be set on ZyWALL310 to resolve signature server if your internet wan type is static IP.0
Thanks @Zyxel_Cooldia for the info.The ZyWall310 is my firewall/NAT so I presume that's going to be fine.Regarding the DNS setup - ao are you saying I need to add an A Record to the DNS settings in the ZyWall 310? If so then how do I find the host name and IP address for the signature server?0
Hi @SMarkG,It’s not adding a DNS A record for signature server. You have to add a DNS zone forwarder for ZyWALL310 DNS query.How to add DNS server on ZyWALL310Go to “CONFIGURATION> System > DNS”, and click “Add” button in Domain Zone Forwarder.Fill in * in Domain ZoneSelect Public DNS Sever. e.g. 8.8.8.8Select external wan interface for query interface.0
Thanks for that. However, I already had zone forwarders for both of Google's DNS servers (8.8.8.8 and 8.8.4.4) in place so I don't think that was the problem.I have since updated the box' firmware though and the signature updates are now working. So I don't know what the original problem was, but the new firmware seems to have fixed it!Thanks anyway.I have a further issue with IDP but will post that in a new thread.0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
