Locked out of USG210
After updating the firmware I was asked to set a new password. I set a new password but I am unable to login.
It looks very similar to this issue: https://businessforum.zyxel.com/discussion/1393/locked-out-of-my-own-usg110
The password did not have a
Sorry, posted an imcomplete draft.
The password did not have a $ but started with '
I have startup-conf downloaded but is there a way to log in without resetting?0 -
Hi @jw708,
If you have the latest backup configuration file "startup-config.conf", search for the following CLI.
username admin encrypted-password $4$encryptedpasswordencryptedpassword$ user-type admin
Then set a new password and replace the following CLI with the original one.
username admin password yournewpassword user-type admin
In this example, 12345678 is the temporal password.
Save and rename startup-config-back.conf. Upload this configuration file to device and apply it.
Here is the procedure.
- 588 USG FLEX H Series
- 477 News and Release
