Zysh daemon is busy
michaelJin
After upgrade to v4.39, I am getting 100% cpu from time to time, there are few alerts "Zysh daemon is busy"
and widget keep loading.
Any suggestion about it?
The CPU is going up quickly if I click refresh widget quickly.0
Trying to set the widget refresh interval to 300, but somehow it is reset to default 0. What's the correct way to update it
Username: adminPassword:
Router# debug system show cpu statusCPU utilization: 99 % (system: 48 %, user: 21 %, irq: 0 %, softirq 30 %)CPU utilization (1 minute): 24 % (system: 9 %, user: 8 %, irq: 0 %, softirq 7 %)CPU utilization (5 minute): 56 % (system: 18 %, user: 21 %, irq: 0 %, softirq 17 %)
Router#debug system psPID PPID COMMAND USER TT PRI NI %CPU %MEM STAT VSZ RSS SZ SZ STARTED ELAPSED TIME COMMAND8559 1 capwap_srv root ? 19 0 0.0 0.2 Sl 87840 4404 76452 21960 Aug 24 4-21:21:12 00:04:25 /usr/local/bin/capwap/capwap_srv -p /var/run/capwap_srv.pid8521 1 tr069ta root ? 19 0 0.0 0.0 Sl 84876 1928 76216 21219 Aug 24 4-21:21:12 00:00:41 /usr/sbin/tr069ta10277 1 capwap_client root ? 19 0 0.1 0.2 Sl 78048 4080 68240 19512 Aug 24 4-21:20:39 00:07:30 /usr/local/bin/capwap_client -p /var/run/capwap_client.pid -m bc:99:11:b0:2e:90 -d3353 1 asd root ? 19 0 0.0 0.0 Ssl 66108 1920 43620 16527 Aug 24 4-21:21:55 00:01:41 /usr/sbin/asd8503 1 wacd root ? 19 0 0.0 0.0 Ssl 65676 1004 59728 16419 Aug 24 4-21:21:12 00:00:41 /usr/sbin/wacd1135 1 secu_reporter root ? 19 0 0.0 0.1 Ssl 59112 2396 52844 14778 Aug 24 4-21:22:06 00:00:09 /usr/sbin/secu_reporter12710 1 radiusd root ? 19 0 0.0 0.4 Ssl 57920 8152 45664 14480 Aug 24 4-21:19:58 00:00:00 /usr/sbin/radiusd -xxxd /var/zyxel/raddb/8748 1 bwmd root ? 19 0 0.0 0.0 Ssl 49784 1084 43356 12446 Aug 24 4-21:21:08 00:00:09 /usr/sbin/bwmd -d2745 1 zyssod root ? 19 0 0.0 0.0 Sl 49276 1344 43404 12319 Aug 24 4-21:22:01 00:05:35 /usr/sbin/zyssod2924 1 policyd root ? 19 0 0.0 0.0 Sl 49144 1336 43464 12286 Aug 24 4-21:21:59 00:00:00 /usr/sbin/policyd8504 1 l2isolationd root ? 19 0 0.0 0.0 Sl 48896 1420 43332 12224 Aug 24 4-21:21:12 00:00:11 /usr/sbin/l2isolationd2940 1 pro root ? 19 0 0.0 0.1 Sl 45056 2660 35832 11264 Aug 24 4-21:21:58 00:04:27 /usr/sbin/proactor1.2/pro10430 1 ModemManager root ? 19 0 0.0 0.2 Sl 42240 4784 27640 10560 Aug 24 4-21:20:37 00:00:00 /usr/sbin/ModemManager --debug3388 1 fbwifid root ? 19 0 0.0 0.0 Ssl 41124 1088 35216 10281 Aug 24 4-21:21:55 00:00:00 /usr/sbin/fbwifid10438 1 accountingd root ? 19 0 0.0 0.0 Ssl 40664 952 35144 10166 Aug 24 4-21:20:37 00:00:05 /usr/sbin/accountingd3417 3410 zyshd root ? 19 0 0.3 0.6 Dl 39576 12460 13648 9894 Aug 24 4-21:21:55 00:26:48 /bin/zyshd -k /bin/zysh -l /var/run/zyshd-init.lock3400 1 2FAd root ? 19 0 0.0 0.0 Sl 35196 1200 26952 8799 Aug 24 4-21:21:55 00:00:25 /usr/sbin/2FAd4525 1 contfltd root ? 19 0 0.0 0.1 Ssl 33360 3824 18788 8340 Aug 24 4-21:21:37 00:00:21 /usr/sbin/contfltd24901 24900 zysh nobody ? 19 0 0.0 0.1 S 32780 2588 1452 8195 11:16:30 00:50 00:00:00 /bin/zysh -x22495 22389 zysh root pts/1 19 0 0.0 0.1 Ss+ 32776 2388 1448 8194 11:09:05 08:15 00:00:00 /bin/zysh -p 10024904 24903 zysh nobody ? 19 0 0.0 0.0 S 32584 1332 1256 8146 11:16:30 00:50 00:00:00 /bin/zysh -x24957 24956 zysh nobody ? 19 0 0.0 0.0 S 32584 1332 1256 8146 11:16:53 00:27 00:00:00 /bin/zysh -x25040 25039 zysh nobody ? 19 0 0.1 0.0 S 32584 1332 1256 8146 11:17:11 00:09 00:00:00 /bin/zysh -x24907 24906 zysh root ? 19 0 0.0 0.0 S 32584 1308 1256 8146 11:16:37 00:43 00:00:00 zysh -p 110 -e show cpu status|xml8498 1 fauthd root ? 19 0 0.0 0.0 Ssl 31484 700 25916 7871 Aug 24 4-21:21:12 00:00:00 /usr/sbin/fauthd2925 1 firewalld root ? 19 0 0.0 0.0 Sl 30156 836 26940 7539 Aug 24 4-21:21:59 00:00:00 /usr/sbin/firewalld8556 1 redis-server root ? 19 0 0.2 0.1 Sl 29680 2172 25812 7420 Aug 24 4-21:21:12 00:18:01 /usr/local/bin/redis-server 127.0.0.1:637910301 1 info_transfer root ? 19 0 0.0 0.0 Sl 29124 1044 24904 7281 Aug 24 4-21:20:38 00:00:11 /usr/sbin/info_transfer3180 1 fqdnobjectd root ? 19 0 0.0 0.0 Ssl 28300 656 24904 7075 Aug 24 4-21:21:57 00:00:13 /usr/sbin/fqdnobjectd2837 1 sched root ? 19 0 0.0 0.0 Ssl 27680 524 25900 6920 Aug 24 4-21:21:59 00:00:00 /usr/sbin/sched10439 1 user_logout root ? 19 0 0.0 0.0 Sl 27312 720 24892 6828 Aug 24 4-21:20:37 00:00:08 /usr/sbin/user_logout1137 1 uamd root ? 0 19 0.0 0.0 SNsl 26476 1808 18060 6619 Aug 24 4-21:22:06 00:01:18 /usr/sbin/uamd2793 1 rumd root ? 19 0 0.0 0.0 Ssl 25992 1416 17808 6498 Aug 24 4-21:22:00 00:00:00 /usr/sbin/rumd10572 1 ttyd root ? 19 0 0.3 0.1 Sl 24188 2676 17860 6047 Aug 24 4-21:20:35 00:21:44 /usr/sbin/ttyd -p 11080 web-console-login8505 1 radio_scheduled root ? 19 0 0.0 0.0 Sl 23224 840 17724 5806 Aug 24 4-21:21:12 00:00:00 /usr/sbin/radio_scheduled2926 1 sessionlimitd root ? 19 0 0.0 0.0 Sl 20840 724 17724 5210 Aug 24 4-21:21:59 00:00:00 /usr/sbin/sessionlimitd3964 1 raddb_wtp_conf root ? 19 0 0.0 0.0 Sl 20208 832 17788 5052 Aug 24 4-21:21:42 00:00:00 /usr/sbin/raddb_wtp_conf8614 1 wireless_hal root ? 19 0 0.0 0.0 Sl 19644 736 17712 4911 Aug 24 4-21:21:11 00:00:47 /usr/local/bin/wireless_hal10451 1 autohealing root ? 19 0 0.0 0.0 Ss 18560 668 328 4640 Aug 24 4-21:20:37 00:00:00 /usr/sbin/autohealing18306 9916 httpd nobody ? 19 0 0.0 0.2 S 18472 4896 2216 4618 Aug 28 1-01:15:25 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL20400 9916 httpd nobody ? 19 0 0.0 0.2 S 18380 4908 2124 4595 Aug 28 1-01:09:35 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19844 9916 httpd nobody ? 19 0 0.0 0.2 S 18368 4816 2112 4592 11:01:07 16:13 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL7119 9916 httpd nobody ? 19 0 0.0 0.2 S 18368 4744 2112 4592 10:22:57 54:23 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19814 9916 httpd nobody ? 19 0 0.0 0.2 S 18352 4780 2096 4588 11:00:57 16:23 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL20364 9916 httpd nobody ? 19 0 0.0 0.2 S 18352 4720 2096 4588 Aug 28 1-01:09:42 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19880 9916 httpd nobody ? 19 0 0.0 0.2 S 18348 4696 2092 4587 11:01:14 16:06 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL20371 9916 httpd nobody ? 19 0 0.0 0.2 S 18344 4728 2088 4586 Aug 28 1-01:09:40 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL21580 9916 httpd nobody ? 19 0 0.0 0.2 S 18328 4724 2072 4582 Aug 28 1-01:06:27 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19881 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4704 1980 4559 11:01:14 16:06 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19836 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4696 1980 4559 11:01:03 16:17 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19921 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4676 1980 4559 11:01:26 15:54 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19876 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4652 1980 4559 11:01:13 16:07 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19837 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4632 1980 4559 11:01:03 16:17 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19820 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4628 1980 4559 11:00:58 16:22 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19832 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4624 1980 4559 11:01:02 16:18 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19821 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4612 1980 4559 11:00:58 16:22 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19828 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4612 1980 4559 11:01:00 16:20 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19916 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4612 1980 4559 11:01:24 15:56 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL19938 9916 httpd nobody ? 19 0 0.0 0.2 S 18236 4608 1980 4559 11:01:28 15:52 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL0 -
Hi @michaelJin,
We need to check why zysh daemon is busy on your device remotely.
I'll contact you in private message for remote access information.
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
