Find connected device
Hi guys,
I'd like to ask you if have an idea, how to find a device (its last connection) according to its MAC address?
Our WC is NXC5500.
Story:
Somebody has stolen two our's BarCodeScanners. I've got their MAC addresses and would like to search the WC logs, where (on which AP) and when, were these two BCS devices connected..
Is it possible?
Thanks a lot, for your time.
Our WC is NXC5500.
Story:
Is it possible?
Best Answers
Hi Joslyn, thanks for your answer, but how can I filter according to MAC address? In View Log there is an IP address requested in the field, I am unbale to search according MAC addresses...
Thanks.0 -
Hi @Ermess
You can search the MAC address via "Keyword". It will also filter the information that you need.
Joslyn5
Hi @Ermess
You can search for the logs with filtering its MAC address. Just use "Show Filter". It will contain all the detail information.
Hope it helps.
Joslyn0 -
Thanks.0 -
Hi @Ermess
Joslyn5 -
It is working. Thanks a lot.
Regards Ermess0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
