VLAN range configuration for CLI
CrazyTacos
I have been using the 3700 series for a while now.
I noticed that you can configure multiple port settings using "interface port-channel x-y".
I tried the same strategy with VLANs but it doesn't seem to work.
GS3700(config)# vlan 5-20
vlan *5-20
% Invalid input detected at '*' marker.
I also tried using "vlan 5 20". The command was accepted. But only VLAN 5 was configured.
Is it possible to enhance the CLI?
Example:
GS3700(config-vlan)# fixed 1-10
Result:
- VLAN 5 to VLAN 20 are created.
- VLAN 5 to VLAN 20 are fixed on ports 1 to 10.
Example:
Result:
Hi @CrazyTacos,
We are glad to hear this idea to improve configuring VLAN for user, after evaluating, this new feature is in Zyxel future roadmap now.
Thanks.Jason0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
