Ping using Virtual interface causing packet loss for WAN to BQM
PeterUK
PeterUK Posts: 4,459 image  Guru Member
edited April 2021 in Security
So I'm back to V4.38(AAAA.0) on Zywall 110 after finding this bug in V4.60(AAAA.0)
On the OPT I have Virtual interface for a LAN 192.168.252.1 and OPT gets the WAN IP but as you can see from this capture every now and then it uses the Virtual interface and not the WAN IP on OPT to send a reply.
I also have a routing rule for incoming ZyWALL source OPTIP next hop OPT which fails to help.
