VPN100 - Edit Ethernet window won't load for LAN interface after upgrading to 4.60(ABFV.0)
2»
  • xbolshe
    xbolshe Posts: 10
    image  Freshman Member
    @xbolshe
    I tested it locally without any issue
    FW:v4.60
    Wan
    Lan
    Does this issue occur on previous firmware version?
    Also, can you private message configuration for check purpose?
    No. It does not.
    I see the following problem:
    After sending commands from 0 to 24 as shown on a picture below, a response like zyshdata + i was returned only for 0 to 16 commands. There is no response for commands 17 - 24. The first command of this list is
    show matching mac oui LAN1_POOL,Static_.....
  • xbolshe
    xbolshe Posts: 10
    I have deleted manually (via command line) static DHCP records for LAN1 interface. And now it works - see a picture below. So, the bug is related with static DHCP records.
    Router# configure terminal
    Router(config)# interface lan1
    Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_xxxxxxxxxxxx
    Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_yyyyyyyyyyyy
    Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_zzzzzzzzzzzz
    Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_cccccccccccc
    Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_nnnnnnnnnnn
  • xbolshe
    xbolshe Posts: 10
    edited November 2020
    May you add several static DHCP records to LAN1 and check how GUI works on 4.60?
  • xbolshe
    xbolshe Posts: 10
    One more interesting point: VPN50 does not support a comma separated list in a command like shown below. It may be a problem.
    Router# show matching mac oui LAN1_POOL,Static_LAN1_xxxxxxxxxxxx
    % (after 'oui'): Parse error
    retval = -1
    ERROR: Parse error/command not found!
    No.  MAC OUI member
    1    33:33:33
    Router#
  • gb5102
    gb5102 Posts: 25
    I am experiencing the same issue after upgrading.
    It does seem to be related to static DHCP reservations as stated previously by 'xbolshe'
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    image  Zyxel Employee
    @xbolshe , @bbp , @Tom2456 , @Bula64 , @RafaelDalben , @noelchiocchetti , @gb5102
    Regarding to this issue, the solution has been released.
    You can download from this Link.
  • RafaelDalben
    RafaelDalben Posts: 11
    THX A MILLION !!! It's working now !!
    V4.60(ABFV.0)ITS-2020-11-23-201100284
     working just fine !!
  • xbolshe
    xbolshe Posts: 10
    @Zyxel_Charlie  I confirm that the problem disappeared on VPN50 V4.60(ABHL.0)ITS-2020-11-22-201100284 / 2020-11-22 15:52:44. Thanks a lot!
  • noelchiocchetti
    noelchiocchetti Posts: 2
    @Zyxel_Charlie I confirm as well that problem disappeared on VPN100 VV4.60(ABFV.0)ITS-2020-11-23-201100284 / 2020-11-23 09:0. Thanks a lot for your swift support!
