How to Update USG 40 from Version 4.13 to 4.60
You can download the current latest release firmware from the official zyxel website.
For your reference the direct link is here.
https://www.zyxel.com/in/en/support/DownloadLandingSR.shtml?c=in&l=en&kbid=M-01438&md=USG40
Here is the complete procedure for the firmware upgrade guide for your Zyxel USG40 .
https://mysupport.zyxel.com/hc/en-us/articles/360008504319--ZyWALL-USG-Firmware-Upgrade-Procedure
Hi @Premium
We recommend upgrade firmware one by one prevent configuration disappear risk.
You can upgrade by this step:
4.13 > 4.20 > 4.30 > 4.33 > 4.35 > 4.38 > 4.60.
I will send old firmware by private message, the others you can download them from Myzyxel.com.
Dear Zyxel support,
I have the same version 4.13 on my USG40 and i would like to follow your suggested path for upgrade.
Could you please send me the older versions as well?
Best,
C.0 -
It should just be possible to upgrade to V4.60 then do a reset.
Thank you0
Hi @adem
I have sent old firmware download link to you by private message.
In upgrade firmware case, you can backup startup-config first. And upgrade firmware to 4.65 directly. It should without problem.0 -
Hi @Zyxel_Stanley could you help me? I have the same problem. I have this swithc 1920-24HP with firmware 4.10. I want to upgrade it to the 4.70 but I can't do it directly as I have to upgrade it step by step with the older firmwares. I can't find them anywhere. Could you help me please? Thank you very much!!!0
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
