replace vpn100 with vpn300
scr
scr Posts: 2
image  Freshman Member
edited April 2021 in Security
Hi. We have a client with vpn100. It has outgrown the cpu at 100%. I want to replace it with a Vpn300. I'm looking at the converters but I don't see how I can do that migration. Do you know if there is a way? Or do I have to do it by hand
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    image  Zyxel Employee
    Hi @scr
    Currently there is no converter from VPN100 to VPN300.
    Since both of model hardware physical port are different.
    So we recommend re-config on VPN300 to fulfill your environment.
  • scr
    scr Posts: 2
    ok
