Zyxel security advisory for hardcoded credential vulnerability
CVE: CVE-2020-29583
Summary
Zyxel has released a patch for the hardcoded credential vulnerability of firewalls and AP controllers recently reported by researchers from EYE Netherlands. Users are advised to install the applicable firmware updates for optimal protection.
What is the vulnerability?
A hardcoded credential vulnerability was identified in the “zyfwp” user account in some Zyxel firewalls and AP controllers. The account was designed to deliver automatic firmware updates to connected access points through FTP.
What versions are vulnerable—and what should you do?
After a thorough investigation, we’ve identified the vulnerable products and are releasing firmware patches to address the issue, as shown in the table below. For optimal protection, we urge users to install the applicable updates. For those not listed, they are not affected. Contact your local Zyxel support team if you require further assistance.
Got a question or a tipoff?
Please contact your local service rep for further information or assistance. If you’ve found a vulnerability, we want to work with you to fix it—contact security@zyxel.com.tw and we’ll get right back to you.
Acknowledgment
Thanks to Niels Teusink at EYE for reporting the issue to us.
Revision history
2020-12-23: Initial release
2020-12-24: Updated the acknowledgement section
2021-1-4: Updated the patch schedule for AP controllers
Is the Zywall 110 affected? Autoupdate is not showing any available updates.0
@inchica
ZyWALL110 is the same with USG series,
FW is available now and you can download from below page:
https://www.zyxel.com/support/download_landing/product/zywall_110_310_1100_13.shtml?c=gb&l=en&pid=20160421155049&tab=Firmware&pname=ZyWALL 110/310/1100
Zyxel_Dick
What is the impact of NXC2500/5500?
Although the firmware is impacted by the vulnerability, it's a lower risk of the current device, below is the detailed information for your reference.
The specific account is only used to connect to the embedded FTP server. The account is NOT allowed to login to the Console/TELNET/SSH/WWW/SNMP v3.
Once login to FTP, the account can only access the “AP firmware” directory and CANNOT traverse to other directories.
Zyxel_Dick
What should I do if I can’t upgrade the firmware in a short time?
1. If you don’t need to deliver automatic firmware upgrade for APs through FTP, please disable the FTP service on the controller. The AP controllers use the CAPWAP protocol as the default design to deliver such updates.
2. If it is still necessary to enable FTP service, please enable the Service Control or Policy Control features for better protection.
Zyxel_Dick
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
