problem with VPN L2TP client-Server USG 100
since a few weeks, i try to configure a VPN L2TP Client/Server. I followed the steps that were indicated in the documentation from Zyxell but when i want to connect to my VPN i have this message on windows :
"the L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the computer."
I checked all the options but I can't find where the problem comes from.
I have 4 VPNs site to site and they work well.
Can you help me?
Thank you,
Dav975
PS: Sorry for my english, i speak french and start to talk in english.
Can you help me?
Thank you,
Dav975
Hello Dav975,
As your description,
does L2TP server behind NAT router? Also, please double confirm the pre-share key is match.
Moreover, here is the SOP of configuration of USG and PC side from FAQ.
PC:
https://businessforum.zyxel.com/discussion/456/how-do-you-configure-l2tp-vpn-between-zywall-and-a-windows-7-laptop#latest
USG: Just ignore step 7.
https://businessforum.zyxel.com/discussion/618/how-to-use-the-vpn-setup-wizard-to-create-a-l2tp-vpn-on-the-zywall-usg#latest
Charlie
Hello Charlie,
my VPN works. On the other hand, I have another problem.
I have two routers (which communicate with each other by another VPN) I have configured my outside VPN and my client on both (as you indicated above).
On one of them I always have internet, but on the other, I lose my connection. But my VPN works because I can join my servers.
Do you have an idea why i lose my internet connection?
Dav975
Hello Dav975,
I want to confirm that do you mean if when "A" client access to internet via L2TP tunnel, another client"B" cannot, however, if when B client can access to internet, A client cannot?
Secondly, do both clients use the same account to login?
Thirdly, I want to check your configuration, please PM to me.
Charlie1 -
Hi Charlie,
I have a Client "A" and 2 USG 100 (USG "A" and USG "B") in 2 different building.
USG "A" has network address 192.168.1.0 and USG "B" has 192.168.2.0
Client "A" has network addres 192.168.1.0 at home.
When i connect Client "A" to USG "A" i have network and my VPN with USG "A". When i connect Client "A" to USG"B" i have my VPN with USG "B" but i don't have network.
ok for network it's working.
Thank you!
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 679 USG FLEX H Series
- 360 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 502 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
