USG20-VPN & AT&T Pace 5268AC
Zyxian
Zyxian Posts: 8
image  Freshman Member
edited April 2021 in Security
I'm hoping someone here has had the same issue and has resolved it or got it to work without an issue.
On the Pace 5268AC I want to set up the USG20 as a Cascaded Router.  But no matter how I configure the USG on the Pace - DHCP or Static - the Pace tells me that the USG isn't configured correctly.
How do I configure the USG so the Pace will accept it as a Cascade Router?
Thanks for any help.
Zyxian
#Biz_Security_June
  • Zyxian
    Zyxian Posts: 8
    Well I got the Pace to see the USG as a Cascaded Router.  It wasn't the USG that needed to be configured.  It was the Pace.
    To set my IP block just as a Supplementary Network, it used the router's IP x.x.x.126 and I could use x.x.x.113-125.  When I put that info into the Cascaded Router section I got an error.  I used x.x.x.112 and it worked.
