Can I connect non-PoE devices to the PoE GS1900-8HP Switch?
ss204u
ss204u Posts: 1 image  Freshman Member
edited August 2022 in Switch
If it is possible then how to disable power for POE port and use it as a regular LAN port? Thank you.
#Biz_Switch_Oct_2018
  • Andye
    Andye Posts: 10 image  Freshman Member
    First Comment Friend Collector Nebula Gratitude Fifth Anniversary
    there is nothing to do, only plug in the LAN cable of the non-POE device. The Switch don´t use POE if it is not necessary.
    br andy
