NXC 2500 " Wrong CLI command" after Login...
Zaddel
Zaddel Posts: 3
image  Freshman Member
edited May 2024 in Wireless
After Login on the NXC 2500, " Wrong CLI command" pops up on every point of the menu. a restart has no effekt.... any ideas ?
  • Zyxel_Kathy
    Zyxel_Kathy Posts: 76
    image  Zyxel Employee
    edited November 2017
    Hi @Zaddel
    Before you login the NXC's GUI, please note that
    1. Turn on Javascript and Cookie setting in your web browser.
    2. Turn off Popup Window Blocking in your web browser.
    3. Turn on Java Runtime Environment (JRE) in your web browser.
    Test the browser with those version.
    The NXC Web Configuration allows easy management using an Internet browser. Browsers supported are:
    •Firefox 36.0.1 or later
    •Chrome 41.0 or later
    •IE 10 or later
    Please confirm the firmware version is using the latest 5.10 and check the pop up message if has the error number or other message? Is any possible share the screenshot for us? Thanks.
    Kathy
  • Zaddel
    Zaddel Posts: 3
    Hey Kathy,
    the issues is still happen with each kind of browsers and settings. Firmware is 5.0...
  • Zyxel_Kathy
    Hi @Zaddel
    I suggest you upgrade firmware to 5.10 by FTP.
    There is FAQ teach you upgrade FW by FTP.
    https://businessforum.zyxel.com/discussion/649/how-to-upgrade-firmware-to-controller-access-point-by-ftp#latest
    Kathy
  • Zaddel
    Zaddel Posts: 3
    Ahoi Kathy,
    upgrading the firmware solved the Problem, cheers :)
  • Zyxel_Kathy
    @Zaddel
    Great news~ =)
  • ChrisGer
    ChrisGer Posts: 206
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    image  Ally Member
    Zaddel said:
    Ahoi Kathy,
    This issue was also existing (but solved) with the pre-Firmware from a USG ;)
    With the last fW release, this issue is solved, too ;)
