GS1900-8HP Cannot access web management GUI
a_different_username
Hi everyone,
I have recently purchased a GS1900-8HP switch and wanted to update the firmware, but I cannot access its management interface via the browser at 192.168.1.1 ("ERR_CONNECTION_TIMED_OUT").
I've connected the switch to my Easybox (192.168.2.1), and my PC (192.168.2.110) to the switch. I can access the Internet, but not the switch itself, and it doesn't show up in the router configuration page under connected devices.
Does that have something to do with the fact that the other adresses are beginning with 192.168.2.xxx and if so, how do I fix it? Thanks in advance!
Greetings!
#Biz_May_2019
Greetings!
#Biz_May_2019
Hi @a_different_username
You can use our ZON utility
https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
to change the management IP of your GS1900-8HP into a static IP 192.168.2.x so that you can login the Web-GUI with your PC.
Zyxel_Lucious
Zyxel_Lucious
Thanks for the quick reply, I'm going to test that as soon as I get home!
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
