zyxel nwa1123 ac v2 - setting working time
Hi all,
I have installed this AP in my home network and I'm looking for the way to shutdown the AP automatically at a certain hour. In the same way I need to reactivate the AP in the morning. In the user manual I don't find specific instructions or cron command. Could you help me?
#Biz_Oct_2019
#Biz_Oct_2019
Hi @duke_64
You can use the notepad to write a script with a certain time as below content and save it to *.zysh file as below screenshot
===================================configure terminalschedule-run 1 FatAPreboot.zysh daily 14:05writeexitwriteshutdown
Upload this file on the AP's shell script and then click 'Apply'.
Hi @duke_64
Our AP supports to shutdown it automatically at a certain time by script, but doesn't support to reactivate it at a certain time.
Actually we support a schedule SSID function to enable or disable SSID at a certain time as below screenshot.
Thanks!0 -
Hi Zyxel_Panda,
many thanks for your answer. Could you explain me how to write the script for the automatic shutdown at a certain hour? I can program an automatic external current switch off 5 minutes after the shutdown, and an automatic switch on in the morning with a cold boot.
Hi @duke_64
Many, many thanks !!!0
- 237 Nebula Ideas
- 6.8K Security
- 742 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
