Data link protection
chadihatem
how to restrict users with usg210 next-gen from downloading big files?? for example i want to set a rule
to restrict users not to downloading files exceeding 10MB in size.
@chadihatem
Regarding to your request, to restrict downloading files not exceeding 10MB in size. The device does not support it so far.
Therefore, I would like to move this thread to ideas section.
Charlie
@chadihatem
I would like to share a knowledge that USG Series support BWM which can limit the downloading and upload speed for each clients. The follow steps as your reference.
Go to BWM and enable it>Create the profile> Select Per-Source-IP(BWM Type) and choose the address object (Client located)on source field> Configure 10000 kbps on Inbound section.
Charlie
hi Charlie, thank you for the reply, this is to limit speed but not file size0
@chadihatem
The current ZyWALL/USG design is to limit the network speed/throughput.
We do not have the plan to implement “file size limitation” function in near further.
Charlie0 -
noted, please let us know once function is ready0
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
