Transfer config from GS1920 > GS1920v2
HI @Hitman
To backup configuration, please go to Maintenance > Backup configuration > Backup
To restore configuration, please go to Maintenance > Restore configuration > upload the file
Further information you can refer to users guide Chapter 39. Maintenance and you can download it in the link below
https://www.zyxel.com/support/download_landing/product/gs1920_series_22.shtml?c=gb&l=en&pid=20130521174252&tab=User_s_Guide&pname=GS1920%20Series
Also, if the old device is PoE device and new device is non PoE or the port number of old device is more than new device, you have to change the config in the backup file and then restore to the device.
Best regards,
Zyxel_Derrick0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
